Draft view border visible, properties box "Show Drawing View Border" not checked
I want to show a partial view of a part. When I adjust the view boudary to do that, the view border becomes visible. Sometimes clicking Update Views will take away one side but at least 3 sides are always visible. The properties check box "Show Drawing View Border" is unchecked. Is there some other option that I dont know about that affects the view border visibility?
Betreff: Draft view border visible, properties box "Show Drawing View Border" not checked
Hi @kjm
I only can assume that You are talking about a small line showing the view border area from within a part model
This can be set ON or OFF under the Annotation tab of the view properties
or tunr on would bring:
Wolfgang
@hawcad Awesome!
You figured out just from the description.
I thought only about the view border check box on the General tab.
It would be interesting to see if this worked for the OP, but nevertheless I learnt something new.
Thanks.
Hi @Tushar
thanks for Your recognizeing words and I hope it is what was asked by @kjm
Wolfgang
Thank you that worked.
@kjm
Please mark @hawcad's reply as the "accepted solution"
Thanks.
Tushar
Hi @Tushar
many thanks for this reply, I never noticed that until now.
But the most important fact is, that we were able to help, answer the question and solve the problem.
Wolfgang
Hi @hawcad Do you mean the wrong answer getting marked as solution.
I can only assume that it was a slight overlook by the OP, but that should be corrected and the right post should be marked as solution, especially for future reference.
Hi @Tushar
Yes exactly, this was my mind behind the last post
But again, thanks for Your engagement
Wolfgang
