Draft views not appearing
One of my users has an issue where the drawing views don't appear in the draft - there's a broken line box around the view instead. In the drawing view properties there is a red exclaimation mark beside the part file.
The drawing is linked to the correct file and it is available - in fact you can still double click the view and it will open the correct part so I don't understand where it's going wrong.
Anyone have any ideas?
[SE ST7, screen shots attached]
Re: Draft views not appearing
Does the file contain a solid body?  It's not a surface or somether than a solid body, correct?
If you want to share the file I could take a look at it.  I have some thoughts I could check.
Brian Fritz
Solid Edge Certified Professional
ST10 latest MP
Check the model for errors with Geometry Inspector.
LMGi
www.TLMGi.com
