Drag component with Detect collisions
Dear all,
I know in the past (last time I tried it was with ST3 or something) than when you move a part with the Drag Component and set the option for Detect collisions the part should stop moving when a collision is detected, ofcoarse the settings must be set correct. Now I try it and no stop or sound.
See the video for the settings and components.
(view in My Videos)
For some reason it does not work at this moment. Working with ST8 MP6.
Could any of you test if you have the same thing happen?
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
Re: Drag component with Detect collisions
I cannot reproduce it here - maybe it's specific to your model?
If you cannot reproduce it than it should be a model think.
Can it happen that a sweep will not work?
Could you try it on your system with this part?
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
I tried with that part and a simple part I created and it still works as expected on my system. Is it specific to that assembly on your system? If so, you may want to log an IR so we can take a look at it.
Greg
Check your Analysis Options. The last one should be checked "Stop movement when Collsion occurs"Capture.JPG
@GregLuckett, I will make a IR by our reseller. You may know it works for the EU Smiley Wink
@TDB, I did. Thank you for the reply.
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
Cleaned my TEMP folder, reboot and now it works.
That TEMP folder, that always solve most of the problems.
Thank you all for the help.
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
Make sure the two parts aren't already interfering.
Using SE since V12, 2002
ST10 certified
Good tip. For some reason I have to close SE completly before I can drag the component before it detects anything. Weird but it keeps working after the reboot of SE.
Daniël Schuiling
Solid Edge ST7
Teamcenter 10
I am facing this issue with ST9
please see attached video.
(view in My Videos)
Would you please tell me a tip how to get this detection workable ?
All parts in the Asy are Active.
Thank you,
Arek
