Drawing Table - only Weldments
Hi Edgers,
I'd like to create a Part List Weldment Table.
What I want to achieve is, I want to have only WLDs on the table, no parts, no sheet metal.
In properties, I named all parts as PRT. , sheet metal as LSR and all weldments as WLD.
I converted all assemblies to weldments - the icon has changed.
My settings:
With these settings, I am getting all parts included: PRT, LSR and WLD. Aim is to have only WLD and WLD subassemblies too.
To get what I want I have to hide PRTs and LSRs manually on Data Tab :
But this method is not ideal.
Would you please to tell me how to play with the settings to achieve what I need?
Thank you,
Arek
Re: Drawing Table - only Weldments
I think you're stuck with the method you indicated. I think it would be nice to be able to filter in/out items based on property values.
edit: you might find this thread interesting if not helpful
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/BOM-based-directly-on-CUSTOM-PROPER...
Bruce Shand
