Drawing View Properties - Captions - Properties
I have a drawing view in which I wanted to show the scale of the view as well as the caption, so I turned on the property to show the scale but I cannot seem to find a place to change the text font or size for the captions properties.
In the image below 1 sets the font details for the caption, but does not effect the settings for 2. I have highlighted the text in yellow that I cannot change the font settings for.
Any help here would be very much appreciated.
Re: Drawing View Properties - Captions - Properties
Hi @Neil_H,
In your template [or now, this document] the OOTB sheet scale is shown on the "Secondary caption" [see Caption type - drop down]
I also have mine set to be combined on the Primary caption, as you might find easier to do.
Solid Edge ST10 [MP8] Classic [x2 seats]
Perfect, thank you Sean.
@Neil_H, If this solved your problem you should mark Sean's answer as an accepted solution.
Bruce Shand
ST10 MP7 - Insight - Win10 - K4200
In the next release of SE could we please have the secondary caption more accessible  - there is so much space on that form that surely there is no need to require a drop-down to get to it.
HP Z420 16GB RAM
Quadro K4000
ST10 MP6 on Windows 10 Pro 64.
Hi bshand,
I have now marked the answer as accepted. Thanks for keeping me on track, usually it is the wifes job but she dosn't frequent this site. Smiley LOL
@Neil_H, Wise guy...
Bruce Shand
