Drawing view model
Is there anyway to change a drawing view model for alternative assembles without deleting the view? Replace?. For instance I have a slide bar that's completely extended "Open". I would like to replace it with "Closed" alternative assembly without loosing the dimensioning.
Re: Drawing view model
I do not think that there is unless you done it as a configuration.  Currently there is no way that I know of to switch the view to a differnent "Family of Assemblies".
Owner: Scott Lester Drafting & Design
Designer: Rotork Instuments
yes, this was a new feature in ST5 i believe (or ST6)
check SE help.
https://docs.plm.automation.siemens.com/tdoc/se/107/help/#uid:index_drawing_production:xid480853:xid...
