Driving an driven dimension
Not applicable
I cannot change status between driving an driven dimension. Option for changing is not available. Could you help me?. Thanks
No puedo cambiar el estado de las dimensiones entre driven y driving. La opción de cambio no está disponible. ¿Podrían ayudarme?. Gracias
James
Re: Driving an driven dimension
Not applicable
James,
What version are you running?
If you are running V100, click on the dimension text.
Click on the lock icon on the dimension value edit dialog.
Rick B.
