Driving dimensions in assembly?
Builder
Builder
http://screencast-o-matic.com/watch/cIjq3bVkIw
Can't seem to place a driving dimension in assembly, is there a way?
Re: Driving dimensions in assembly?
Esteemed Contributor
Luke,
Is that really the way you want to drive this assembly?
Would you not want to position to the holes instead, then mod a part to get the size needed??
Builder
Builder
That's a good point, what I was hoping to do was position the outside dimension, because it's critical, then transfer geometry over to the left brackets to create hole features... If that makes sense.
Hello Luke,   I would achieve this by using Assembly Vari...
Hello Luke,
I would achieve this by using Assembly Variables.
See http://screencast.com/t/oFjVsKvX6l9a for how to.
Cheers
Mark
Re: Hello Luke,   I would achieve this by using Assembly Vari...
Builder
Builder
Thanks Mark!
