EDITING WITHIN A CALLOUT IN ST8
In ST7 and earlier versions, I was able to use the great editing features in MS Word to create a text document and then copy it into a CALLOUT. To facilitate this action, pressing the right mouse button while in the CALLOUT would display a context menu. In ST8, nothing happens when pressing it.
I tried shortcut keys while in the CALLOUT and found CTRL X = CUT, CTRL C = COPY, CTRL A = ALL, & DELETE will work. But the most important combination, i.e., CTRL P = PASTE, does not.
Is this a known bug that I have to live with or is this something unique to my software?
Ron
Re: EDITING WITHIN A CALLOUT IN ST8
Hi Ron
It seems to work for me with ST8
I selected the text in the text document and copied to clip board with ctrl C.
Then I pasted into the callout test field with crtl V
hope this helps
Pete
Pete, thanks.  However, you said you used Ctrl+V to PASTE.  In my ST8 CUSTOMIZING WINDOW/KEYBOARD, it shows Ctrl+P is the speedkey for PASTE.  But when I used what you did, it also works for me.  I don't know why I have Ctrl+P but I will change it to Ctrl+V. And doing a little checking, Ctrl+V is the Windows default speedkey.
Appreciate you solving this one for me.
Thanks again,
Ron
