Ed
N/A
In the Tutorial to draw a rectangle with 2 points the width hight and angle don't change . the are all stuck at 0.00mm ????
Re: Ed
N/A
The width, height and angle will remain zero until after you click for the
first point.
These are the values to defint the rectangle from the first point clicked.
Do you see the rectangle displayed in dynamics after you click the first
point?
Rick B.
Re: Ed
N/A
thank you, it works ! I didnt do the first click
