Edge Design Configurator
At SEU 2013, there was a presentation on Edge Design Configurator by EDA.
See http://www.thecadinsider.com/2014/05/create-parts-using-spreadsheet-with-solid-edge-design-configura...
Their web link doesn't work any more so I'm assuming they are no longer in business? Does anyone have any info on them or tools that work in a similar way?
5 REPLIES 5
Re: Edge Design Configurator
Hi @Alan,
You may be right, even the Siemens page for them has a non-functioning link.
https://www.plm.automation.siemens.com/en/products/solid-edge/applications/design-management-configu...
The links on that page don't work though!
....AHA....it may be, because they changed their name, from EDAinc to EDAeng. [looks Autodesk oriented, is this even the same entity?]
https://www.edaeng.com/
@AmyReyes &/or @KatieKing .....maybe one of you could look at fixing the link, if it's still appropriate there that is.
Nice try Sean, but not the same company.
Make of this what you will but doing some quick digging around....
http://www.edainc.net/ is registered to a location in Bellingham, WA, USA:
LinkedIn shows EDA as being based in Bellingham, WA:
2018-04-05 22_37_53-Engineering Design Automation Inc._ Overview _ LinkedIn.png
Doing a search of business licenses in Bellingham, WA shows that EDA was closed in 2016:
If you're still looking for something more concrete, from the WHOIS results are some contact details:
