Electronic Wiring Problems?!
Hello everyone!
This is a discussion started to answer questions about the wiring for the F24 Kit Car!
What makes me qualified to talk about this? I have built or assisted in building over 100 of these kit cars and have seen it all when it comes to wiring issues.
Hopefully these images will help you in building your kit car!
3 REPLIES 3
Re: Electronic Wiring Problems?!
I am trying with my group to make sense of the battery connecting so that we can create the 24 volts... could you explain in a little more detail how to do it? we have successfully connected everything else we just cant work out how to connect both batteries together and then power the motor...
Kind Regards
Team Liskeard!
You'll need to wire them in series, so the voltage of each battery is added to make the 24V.
Wonderful!
Thank you very much indeed!!!!
Sent from my iPhone
