Element number into annotation/balloon callout
How to add element number into annotation (please see pic. 1) that could swich automatically when part list reschedule ?
Thank you!
CB
Re: Element number into annotation/balloon callout
Community Manager
What version of SE are you using? It looks like maybe ST6 or before? The capability you are after is called "reference text" and it was new in ST7.
Dan Staples
I'm using ST6. Thanks for your attention.
Sir, Can you release this option in next MPack for ST6? It would be niceSmiley Happy) Thank you.
Community Manager
Sorry, but no dice. We can't release functionality in MPs. Plus this was a huge project and it was only tested in ST7 along with all the code changes there -- so it would not be feasible to put in ST6 and redo all that testing.
Dan Staples
Right. Maybe you can release only this part of code as a seperate free macro in developer community?
Anyway, I think I will fully use ST7 quite soon.
Thank you Sir for this first hand info!
If that's the parts list item number, you can already do that in ST6 (and earlier).
On the Callout properties page click the Property Text button, then select From Graphic Connection, then select Parts List Item Number from the list.
Use the Save As to retain for later use.
HP Z420 16GB RAM
Quadro K4000
ST10 MP6 on Windows 10 Pro 64.
The beachcomber Wonderfull! I didnt know that. Thank you!
