Engineering Reference iso din etc
Hi there, I've used the engineering reference with ST7 many times in the past using ISO. Now I need to use DIN and JIS for a couple chain sprockets. However ISO is working but ANSI, JIS and DIN are not, I've tried the maintenance packs and re installing but still no go. We have another pc here with the same software installed and that pc does work. Any idears anyone, please.
Many thanks
