Eploded Views
I have two questions regarding exploded views. See image below and attached files.
David McMahon
Solid Edge 2019
HP Z2 Mini, Windows 10
Re: Eploded Views
Hi @David_McMahon
I found a method to make 3D sketch invisible in Draft :
just un-thick this box.
Re: Eploded Views
Hi @David_McMahon
another method to make 3D sketch invisible:
Re: Eploded Views
Hi @David_McMahon
unfortunately, this method doesn't work.
Re: Eploded Views
Hi @arekkul
Hi @David_McMahon
blanking the sketches in assembly is showinbg the proper result in draft.
Maybe You have not saved the Exploded config after blanking the sketch lines?
Wolfgang
Re: Eploded Views
Hi @David_McMahon
so will this work for You too?
Wolfgang
