Erasing elements
I have been able to dowload ST6 but in trying to erase an element can only do so if I use Cut and transfer to the clipboard.  I s there another way without doing this?
POP15
8 REPLIES 8
Re: Erasing elements
Hi there @Pop15,
Does the delete button on your keyboard, not actually delete the entity[s] selected?
No .When I  pick element  it changes colour to purple.  If I then press the right key of the mouse and then use the delete button it will disappear, but this seems a roundabout way.
@SeanCresswell wrote:
Hi there @Pop15,
That does, yes.
To be clear, this is not how it should be functioning!
I can't say I've encountered that at all over the last 15 years using Solid Edge. Suspect it's a local setting, or a system display related issue that is at play here.....but not having experienced that particular oddity before, I can't suggest what to do next. Somebody else might chime in with a pointer, or solution.
Hi @Pop15,
Perhaps we need to start this, from the begining......
Can you give some information on your version of Solid Edge ST6 [+ maintenance pack, if any] and of your computer specs. [Operating system, cpu, ram, graphics card & driver version]
Maybe a video of your workflow so we can get a clearer idea of what's going on?
Bruce Shand
Hi
Many thanks for your response, but I have now been able to carry out the correct procedure.
Pop15
This email has been checked for viruses by Avast antivirus software.
http://www.avast.com
Thanks for your reply, and I have now found the correct procedure for erasing elements usinf the delete key.  For your further information I have only recently downloaded and started using the software so everything is a learning curve. I do not know the version of Solid Edge ST6 I have nor do I have any maintenance pack.
Further information you requested is as below:
Operating system 32 bit
Cpu  Intel(R) core(TM)2 Duo  T6400 @ 2.00GHz 2.00GHz
RAM 4.00GB (2.97 GB usable)
Graphics card ATI Radeon
Pop15
Yes I have now found the correct procedure for deleting entities using the delete button. Many thanks for your help.
pop15
