Error Extruding
Hi, i am using the Solid Edge ST8 academic version and get a error while trying to extrude.
The error is: extrudedprotusion with a yellow triangle. Tried reinstalling the program with no luck.
8 REPLIES 8
Betreff: Error Extruding
I think this is more or less a logical problem with YOur choosen geometry or with the length value of Your protrusion.
But without any picture or movie it will be hard to get the right idea what reall might be the problem.
Wolfgang
Re: Error Extruding
Hi
Which Solid Edge MP? use now on your computer?
Please delete content of Temp folder.
Tibor
Re: Error Extruding
I tried deleting everything in temp without any success.
Re: Error Extruding
Swich off all aplication (Solid Edge, Outlook, ....) and after %temp% and delete.
Re: Error Extruding
Where can i find the MP?
It's Solid Edge student edition ST8 with an acdemic code activation.
Re: Error Extruding
Tibor
Re: Error Extruding
a.f.a.i.k. academic activation won't have an MP.
As @hawcad has mentioned the yellow triangle, especially with an extrusion, has more to do with the selected geometry and the extrusion extent and post extrusion geometry condition.
A picture or video will help fix your issue faster.
Re: Error Extruding
Wasn't able to find any MP. I'll post photos when i am able to.
