Error in Mold Tooling
Not applicable
Dear All,
The Mold Tooling module start of the project I get the following error message:
EXCEPTION caught in .\commands.cpp@3584:
EXCEPTION mpfstd_fail_ProgramError:TEXT preference not found in registry (DataPath)
Do anyone have the same problem? Any solution?
Thanks for your help!
Re: Error in Mold Tooling
If you haven't solved this problem yet, here is my answer to this problem!
