Error in Simulation
N/A
Dear All,
I have the following problem when i try the simulation module: When the results are processing there is an error message saying that even there was not fatal errors, results where not generated.
Do anyone have the same problem? Any solution?
Thanks for your help!
Re: Error in Simulation
Innovator
Innovator
Hello!,
Whitout having the model at hand is difficult to help you, please write a ZIP file and post your model here, OK?.
Best regards,
Blas.
