Error message when trying to install ST7
I'm trying to install ST7 on my home computer and keep getting an error regarding the installation of the assembly component.  I'm installing off of the DVD. and it has failed 3 times.  Attached is an image of the error message.  Here are the specs of my home computer:
Asus X58 motherboard
Intel i7 950 processor
16Gb of RAM
Windows 7 pro 64 bit
I have a gaming video card on this machine, but have run ST3 on it with no issues and since I'm not even to running ST7, it's not a factor yet.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
4 REPLIES 4
Re: Error message when trying to install ST7
Any ideas on this one?  I also downloaded ST7 and tried to install it just in case the DVD has some issue but got the same error.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
Hello Kyle,
Don't know if it will help but here is a link to a possible solution
http://www.youtube.com/watch?v=FJHiBl4JCMg
It talk about repairing .Net Framework.
If I remember well, Solid Edge installs .Net at the beginning of the install.
Maybe your .Net install is broken and repairing it will allow you to go further in the installation process.
Best of luck,
Michel
Micheal,
I think there is something wrong with my .net framework.  When I run Windows update, I get a failure message for .net.  The only message I get from Windows is an obscure error code 66.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
I did some cleanup on .net framework but ST7 is still failing on install.  I'm not sure what the issue could be.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
