Error on install
Not applicable
I am installing SE Free on a Vista as an admin. I am getting the following message. File "C\Users\dhoffman\AppData\Local\Temp\_is257.tmp" can not be found. Make sure the file is on target system or installed already.
Re: Error on install
Please read the post titled "IF 2D DRAFTING FAILS TO INSTALL - READ THIS".
You will find a solution there.
Rick B.
