Error when firing up an "old" macro
When I fire up an older macro original written by Greg Chasteen and  modified by Klaus I get an error.
In version ST 9 it worked.
Anyone out there with an idea how to solve this error.
Kind regards,
Jan Bos
Emmen, The Netherlands
8 REPLIES 8
Betreff: Error when firing up an "old" macro
Hi @Jan_Bos
I suppose - or better I believe I know it - this has to do with the deleting of all 32bit APIs with ST10.
A very good solution to run them nonetheless is, to extra install "View and Markup" from the installation image.
This is a 32bit application and installes all the necessary APIs for thos old macros.
At least here for me it solved all that issues!
Wolfgang
It worked... Many thanks Wolfgang.
Hi @Jan_Bos
welcome and I'm happy to have a solution for the moment.
I'm a little bit angry about what will be if this will not bring the solution in future releases.
What shall we do with all the old macros we have.
@uk_dave
Here a solution  will be necessary for future releases, to prevent such situations!
Macros should work, or at least there is a need for transforming old vb6 macros to .net automatically!
Wolfgang
hi ~ hawcad ..
You are such a wonderful person.
Good information, thank you.
HI @Hclee
Hclee schrieb:
hi ~ hawcad ..
welcome, and it always is a pleasure to hear such a statement on a Friday afternoon Smiley Very Happy
Wolfgang
Could you clarify on were I can find the View and Markup in the installation image? I cannot find it!
Thank you in advance!
Hi @Korst
no You will not find V&M in  the standard installation image of Solid Edge.
There is an extra download file for V&M only
Download this one and run the install/setup
Wolfgang
Thank you! All my macros work again now!
This week we will look at upgrading to office 64 bit, to prevent this kind of issues for the next update.
