Error while extraction
Friends
I get the following error while I am extracting. I am using Windows 10 OS. Could someone help me with this. I have attached the screen shot of itCapture.JPG
5 REPLIES 5
Re: Error while extraction
Hi there,
Can you expand a little on this...? What file are you trying to extract??
I have downloaded the file Solid_Edge_ENGLISH_ST8 from website. When I open
it, it comes " Extracting" and at the end the following error comes.
*Regards*
*Akhil Varghese*
*+49 17667065254*
OK....my first though is that the download was interupted, and has become corrupt because of that.....in which case, I suggest re-downloading the file.
Are you on Windows 10 by any chance?...and if so, have you had Solid Edge installed prior to Windows 10??
Hi
I have the same problem and yeah i have windows 10 and i want to install Solid Edge for the first time
I've already re-downloaded
@MatthiasLo wrote:
Hi
Hi there,
Before you install Solid Edge, you will need to download and install Microsoft .NET framework 3.5  >heres a link< ...then provided your downloaded SE installation file is complete [ie; not corrupt] then the install should go through as expected.
