Excel object view
Not applicable
Trying to get an excel object to display correctly and cannot seem to get the view
in solid edge to show the entire spreadsheet. Within excel, I have tried setting
the print area, re-formatting cells, saving externally and then re-inserting to
no avail.
When the external spread sheet is inserted every thing looks good until I edit it.
Then it reverts back to a 12 column wide view.
Are there limitations to this object feature with Excel?
