Explode text ?
SE6 2D, is it possible to explode text so that I can modify it ?
Hi there,   I see no way for you to do this in the 2D env...
Hi there,
I see no way for you to do this in the 2D environment.....I see this as a big gap in the current tool set.
Solid Edge ST10 [MP8] Classic [x2 seats]
Check out DeskEngrave.  This *free* tool will convert a s...
Check out DeskEngrave.  This *free* tool will convert a single line of text using any True Type font into a DXF file.  You can then import that DXF file into Solid Edge; effectively giving you "exploded" 2D text.
