Explotion title rename / edit cfg file
Hi Guys,
I couldn't find it. Is it possible to rename explotion name w/o losing anything?
BTW Is it possible to edit cfg file? If yes, how?
Thank you very much!
CB
Re: Explotion title rename / edit cfg file
I don't believe you can rename an explosion configuration, but you can simply save a new configuration with the new name and then delete the old configuration. Do not delete the old name until you have saved a new configuation with the desired name.
I also do not believe you can edit the .cfg file directly.
Bob Henry
REH Technical Consulting
Canonsburg, PA 15317
