Export Assemby Drawing View as Dwg keeping Tree as Block
Hello
I'm looking for information to be abble retrieve the assembly tree as block tree when I save the Draft as Dwg.
I do a layout with conveyor and other products and I have to send it to final customer as Dwg Files.
In this Dwg file, I must retrieve the same tree than in  the 3D model but as block allowing to move easily each component .
Does Someone have an idea about it ????
Of course, I tried options when I save as Dwg but the best result give me groups with names SE.. and differents than assembly tree.
You can Find as Attached Files, The view of the 3D model to see the tree ans the Drawing View of this Layout without 3D Files to save as Dwg.
Thanks all for you Help
Kind Regards
Steve
Steve Fealinx
Re: Export Assemby Drawing View as Dwg keeping Tree as Block
PLM World Member Genius PLM World Member Genius
Have you try save each par on it own layer
Their is an option when you save to DWG. Not exactly what you are looking for but maybe you can manage to do something with it.
