Export SE settings
Is it possible to save program settings in ST7?
We're upgrading to ST8 and would like to know if it's possible to export/import settings.
Kenneth
9 REPLIES 9
Re: Export SE settings
Kenneth,
You should have some default "Themes" as well as any customized themes located here:
C:\Users\grayson\AppData\Roaming\Unigraphics Solutions\Solid Edge\Version 107\Customization
You can copy/paste these wherever you want.  These themes also carry across from version to version.
Kevin Grayson
Solid Edge Technical Consultant
kevin.grayson@siemens.com
Thanks, going to look into that Smiley Happy
Update:
That did not work.
I copied everything in:
C:\Users\kenneth\AppData\Roaming\Unigraphics Solutions\Solid Edge\Version 107\Customization
To:
C:\Users\kenneth\AppData\Roaming\Unigraphics Solutions\Solid Edge\Version 108\Customization
Program settings are still reset to default.
Settings are stored in 3 places that I know of:
C:\Users\yourusername\AppData\Roaming\Unigraphics Solutions\Solid Edge\Version 107
C:\Program Files\Solid Edge ST7\Preferences
HKEY_CURRENT_USER\SOFTWARE\Unigraphics Solutions\Solid Edge\Version 107
What needs copied from each area, I'm not sure...
http://Grundey.blogspot.com
But there are no "export settings" option then? Smiley Sad
Coming in ST9:
http://www.engineering.com/DesignSoftware/DesignSoftwareArticles/articleType/ArticleView/ArticleID/1...
Awesome, thanks Smiley Happy
Ribbon themes:
C:\Users\username\AppData\Roaming\Unigraphics Solutions\Solid Edge\Version 10x\Customization
Default settings: (under C:\Program Files\Solid Edge ST8...)
Custom hole settings, view scales, etc. are saved in ...\preferences\custom.xml
Custom BOM styles are saved in ...template\reports\draftlist.txt
Custom callouts are in ...\template\reports\draftcallout.txt
Custom weld symbols are in ...\template\reports\draftweld.txt
Templates are in ...\template
Materials are in ...\preferences\material.mtl. Edit (I'm not sure about this one. It may just be our custom one)
Global settings for SE to find most of these things via the file locations in SE options reside in \preferences\options.xml.
Bruce Shand
Do you know where links are saved (the ones in Solid Edge Options -> File Locations)?
Examples:
Link to user templates
Link to hole file
Link to gauge file
etc.
You can use seadmin.exe to edit it.
Bruce Shand
