Re: Export and Import Parasolid Format
Hi @bshand
Yes, but all parts join into one body. I also need them be separated just as in .asm. Smiley Happy
So you want a multi-body part then? And now you have it, right?
Are they construction bodies or design bodies?
Bruce Shand
@bshand
Yes. I got it by exporting .asm to .x_t and then importing to .par.
Guan
While we're on this topic does anyone know why the button for "merge solid bodies" is on by default and greyed out?
Bruce Shand
@iceguan wrote:
@bshand
Guan
OK. That's not necessary in ST8 apparently.
Bruce Shand
@Tauform this is a Solid Edge forum, you might get an answer better by posting on the NX forums.
