Export custom themes
Hi Guys
Just got a new laptop and installed ST8, but I want to get my custom theme from the old laptop to the new laptop.
I can't find a way to export themes.
Any suggestions?
Cheers
Pete
Re: Export custom themes
Hi Pete,
You should be able to copy/paste the theme data from your old machine, I think it's located in your user account App Data folder. Not sure how to apply it restorspectively, as it's normally there for the installer to read from when loading. [possibly have to reload SE]
....on my machine it's located in:  C:\Users\Sean Cresswell\AppData\Roaming\Unigraphics Solutions\Solid Edge\Version xxx
Hi Sean
Worked a treat , thanks.
I copied my custom theme folder from the path you suggested to the same location on the new laptop.
Then started SE2d and selected my theme from the customise menu. Job done.
No need to reinstall.Awsum
Cheers
Pete
Awesome...glad it worked.
