Export search results to a spreadsheet
Is it possible to export your Solid Edge search results to a spreadsheet? How would you do it? I tried printing the results to a pdf file and copying the pdf file into the spreadsheet to make a table, but the results didn't come out right.
If I understand you correctly, you are using the Search f...
Siemens Genius Siemens Genius
Siemens Genius
If I understand you correctly, you are using the Search function on the Solid Edge File Open dialog. Once you have the search results, you can select the cells in the table, right mouse click and copy the contents (see attached image). And then paste into a spreadsheet.
Aditya Gurushankar
Manager, Solid Edge Planning
