Exposing Variables
Honored Contributor
Honored Contributor
I'm attempting to use an asembly variable in an assembly driven part. By exposing the variable, that becomes available in draft. No problems. However when designing a part, how do I make the assembly variable available there? I have tried both standard and peer variable options and the assembly variable will not show up within the part.
Re: Exposing Variables
Open the variable table in the assembly and right click on the row of the variable. Select "copy link" and then go to the variable table in the part and past it to a new row. You may have to name the new variable first I haven't done this for a while.
Using SE since V12, 2002
ST10 certified
