Extrude, Retract within 3 Steps
Good Evening Everyone,
With this doc. Requires a three step procedure with extrude and retract from a positive to a negative or up, down. As the video shows the center hole extrude but, the other step with not work. I do not understand!
http://screencast.com/t/n6WlHMU5Pw
Thank You
Greg
Re: Extrude, Retract within 3 Steps
I imagine the reason is because you are causing a zero thickness non-manifold body between the center and the petals. To check create a new body and extrude them.
Production: ST10 MP7
Testing: SE 2019
http://Grundey.blogspot.com
