Extruding in Increments
PLM World Member Builder PLM World Member Builder
This video shows the issue I have... I am trying to extrude to add not remove an extrusion. But, I am showing an explanation point. These boxes are in increments, to your left to right sets goes up in elevation. I've tried to shift, ordered no luck.
http://screencast.com/t/p05Q5psYH
Thank You
The error that keeps popping up (non-manifold) is a resul...
Esteemed Contributor
The error that keeps popping up (non-manifold) is a result of your new solid just touching another existing solid at a boundary where they neither share material nor are the separated by any space (thus the zero thicknes).
Production: ST9 MP10
Testing: ST10 MP3
Re: The error that keeps popping up (non-manifold) is a resul...
to follow up on Ken's Comment. Depending on you design need you could create a multi body. Adding a new body would absolve the Boolean errors.
Matt Johnson
Application Engineer
Ally PLM Solutions
matt.johnson@allyplm.com
http://allyplm.com/
Ken is right about the cause of the exclamation point err...
MLombard
Retired
Ken is right about the cause of the exclamation point error. To work around the error, you can use a symmetrical end condition, or extrude a short distance in the other direction as well. Let us know if that works for you.
,<edit> Matt's solution of going multibody should also work.
