FACE STYLE - TEXTURE LOAD ERROR .............ERRRRRRRRRRRRRRRRRRRR
Builder
Builder
Anybody else have this issue??? Ive been with SE since ST4 and this has always happened to me and cannot figure out why i have parts losing there texture links (stored on network). This happens randomely and sometimes even to only certain parts (wheras other parts will not have lost its link that shares the same texture).
This has been an ongoing issue for years. Sometimes I have to edit 30,40,50 parts and re-link the texture file its cant find....................even though the "ERROR" is telling me where that particular .jpg is?!?!?!?!?!? With the help of keyboard shortcuts i have become a re-linking master, BUT i shouldnt have to be.
*If anybody could shed some light on this i would GREATLY, GREATLY appreciate it!
-Nate-
Re: FACE STYLE - TEXTURE LOAD ERROR .............ERRRRRRRRRRRRRRRRRRRR
I had similar issues in the past.  I ended up re-mapping my template files to the UNC server path.
So instead of G:\Engineering\Textures\xxxx it started with \\MGMTServer\Engineering\Textures\xxxx
Russ
