FEA Mesh Color?
How can you change the color of the mesh after meshing with the FEA add-in?
Before, I've only seen the mesh represented as black lines over the existing part color, but in this case, the mesh seems to cover over the color of the part. The part was originally colored in green, but the mesh is white... Which seems odd.
How can I change this to view the mesh better?
Cheers,
Nevin
"The society which scorns excellence in plumbing because plumbing is a humble activity, and tolerates shoddiness in philosophy because philosophy is an exalted activity, will have neither good plumbing nor good philosophy. Neither its pipes nor its theories will hold water." -- John W. Gardner
Re: FEA Mesh Color?
Siemens Legend Siemens Legend
Siemens Legend
Nevin,
could it be 'View styles/shaded with Visible edges' that was unset? This adds the edge display.
Regards /ulf
Siemens EMEA GTAC Support
Re: FEA Mesh Color?
@Ulf_Eriksson, Yes, that seemed to fix it. Thank you!
