FRAME ENVIRONMENT
IN THE SOLID EDGE FRAME ENVIRONMENT:
-Is it possible to set up frame part numbers for "Frame enviornment" in Solid Edge?
-The tree in the assembly environment only lists the material type as the name.
-On the drawing, there is a "Document Number Category, but this does not update with any kind of name.
-Also, is there a way to created detail views or drawings of each frame member component? I do not see how to do that.
Re: FRAME ENVIRONMENT
Community Manager
Any way/plan to move up to something more modern. The amount of improvements in the TC connector (SEEC) and Frame since ST3 is staggering.
Dan Staples
