Face Style be copied to several assembly parts at once
Builder
Builder
Edgers
Can a single Face Style be copied to several assembly and part files in bulk?
If so how do we do this OOTB from Solid Edge ST9?
Thanks for any help
Phil
ST9
WIN 7Pro 64bit
DELL T5810 3.7-4Ghz 32Gb ECC
Re: Face Style be copied to several assembly parts at once
take a look at the OpenSave utility delivered here: C:\...\Solid Edge ST9\Custom\OpenSave
I belive you can replace C:\...\Solid Edge ST9\Custom\OpenSave\bin\SourceStyles.asm  with your desired "copy from" template and then run the C:\...\Solid Edge ST9\Custom\OpenSave\bin\OpenSave.exe and your should be good.
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
Builder
Builder
Thanks Matt thats a great tip.  I was unaware this was possible and I doubt it documented.....I'll take a closer look
Phil
ST9
WIN 7Pro 64bit
