Family of Assembly
I have an assembly that has (2) members of the same family in it (Frame Front) & (Frame Rear).  When I run my reports or put the assembly on a draft the quantity shows (1) of each.  How do I get it to show a quantity of (2) other than mess with the occurance property? We are on ST7 service pack 8.
3 REPLIES 3
Betreff: Family of Assembly
but IMHO there You have 2 different assemblies in Your top assembly.
"Frame Rear" and "Frame Front"
I think thos are to diffenret ASM and will have to different document number, have they?
If not, what is the diffenrece for them, and if no diffenrece, what was Your indent to make an FOA?
Wolfgang
They are the same assembly with one part in that assembly in a different location.
OK, I understand.
But - suppose it is a moveable part - the assembly has the same document number.
In that case You should use an FOA - alternate position rather then a real assembly family.
Here You only can chnage variable to drive the position of certain parts instead of having different BOMs.
Or You can let Your assembly adjustable (sorry I don't know what exactly is used in the English Solid Edge version) instead of a rigid one.
Wolfgang
