Fast Search on File Server
Hello together,
i installed fast search on my fileserver yesterday. Everything went fine and the indexing has finished.
I am a bit disapointed. The search is fine for asm par and psm files. But why didn't siemens implement full text search for draft files? Only the propertys of the draft files are in the index.
A manual solution does exist Searching-for-Text-Content-in-Networked-Unmanaged-Solid-Edge
Can this solution work together with fast search?
Couldn't the full text search be implemented in the fast search solution?
Greetings from Germany
Christian Kunkel
https://c-k-m.info
