Fastener system are not restore up dialog?
Dear all;
How I can fix Fastener System. It not restore up dialog. (ST9,MP06) please see avi file.
(view in My Videos)
Re: Fastener system are not restore up dialog?
I do not know if it helps, but you can "reset" Fastener Systems window position by deleting following registry key:
"HKEY_CURRENT_USER\Software\Unigraphics Solutions\Solid Edge\Version 109\General\Position\AssemblyComponentSelection"
After retarting Solid Edge FS window should be located in upper left corner.
Ota
It did the trick even with Solid Edge 2019! Great tip! Thanks you.
