Re: Few questions about my draft file
I know you probably aren't interested in this, but for diamond or treadplate, I have two different blocks set up that depicts the pattern, one in phantom lines, the other in solid. Works well, and it doesn't take all that long to place.
Solid Edge 2019
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
Honored Contributor
Honored Contributor
I will end up using hatch patterns and trimming till I can find a better solution in 2D. I would be interested in the hatch patterns you have set up for diamond plate.
I don't have hatch patterns set up. Just predrawn blocks I use.
Here's the one I use for diamond plate. It's in phantom because usually the diamond pattern goes on the outside of things, and I like to make my flats as bend up whenever possible. Also Including one of the one's I use for decking.
Solid Edge 2019
Honored Contributor
Honored Contributor
Thank you Nominus. I will give this a good look when I get back to sheet metal tasks.
Today is my first day of attempting welds and it has not been going well. I appear to always have geometry that is one step too complex.
Yeah everything but fillet welds or label welds don't usually go that well for me.
Solid Edge 2019
