File Save Issue ST9 MP6
Is anyone else running ST9 MP6 experiencing SE parsing through files mulltiple times for a file save? See the video below, watch the lower left corner prompts and status bar. It saves 3 files that changed and then parses through the same files 4 times. Any clue why? I did not notice this prior to the MP6 update.
https://www.screencast.com/t/etNiNtreQG8
Thanks!
Re: File Save Issue ST9 MP6
Has the assembly always been an Alternate Assembly?  Incedentally, do you happen to have 4 members in it?
http://Grundey.blogspot.com
The 4 alternate assemblies were there before this started happening.
