File locked - ST 4
Siemens Master Siemens Master
Siemens Master
From: Newsgroups: private.se_free2d Subject: File locked - ST 4 Date: Sun, 17 Jun 2012 20:32:03 +0100 Lines: 2 MIME-Version: 1.0 Content-Type: text/plain; format=flowed; charset="iso-8859-1"; reply-type=original Content-Transfer-Encoding: 7bit X-Priority: 3 X-MSMail-Priority: Normal Importance: Normal X-Newsreader: Microsoft Windows Live Mail 15.4.3555.308 X-MimeOLE: Produced By Microsoft MimeOLE V15.4.3555.308 NNTP-Posting-Host: 146.122.132.100 Message-ID: <4fde30b3@dnews.industrysoftware.automation.siemens.com> X-Trace: dnews.industrysoftware.automation.siemens.com 1339961523 146.122.132.100 (17 Jun 2012 15:32:03 -0400) X-Authenticated-User: Colin.hurrell@gmail.com Path: dnews.industrysoftware.automation.siemens.com!not-for-mail Xref: dnews.industrysoftware.automation.siemens.com private.se_free2d:4741 Ricky, A file I was working on refuses to open (Windows 7, Solid Edge 2D draft ST 4). If you try there is an error message: 'The requested file is opened exclusively and cannot be accessed at this time.' The options are: OK, Notify me when available, Copy, Help - none of which does anything. Looking at the File Status it is described as 'Obsolete'. This happened once before with an earlier version of Solid Edge 2D drafting. The present file is small and reworking the drawing is not difficult - it would be very frustrating with a complex file! Can you help? Many thanks, Roger
