File name of Revision Manager
I am using the shortcut -as Makro- of View and Markup to get then access to Revision Manager -iCnct.exe-.
What's the file name of the Revision Manager to be able to use it as shotcut directly from the PAR/ASM/DFT/PSM, without opening the View and Markup and then switching from there to the Revision Manager for file Edit/Copy? I can't find it!
View and Markup  iCnct.exe
Revision Manager *.exe
Yasser
Re: File name of Revision Manager
iCnct,exe -r
