File - pre release version
Not applicable
Good morning,
I have a file created a couple of months ago in version ST3. Trying to open
it I get a message: 'The file was created with a pre-release version of the
software. The file is no longer valid.'
Can you suggest how the file can be opened - it was not created in a
pre-release version.
Many thanks,
Roger
Re: File - pre release version
Roger,
Are you now running ST4?
Send the file directly to me as an email attachment and I will see if I can get the file fixed.
Rick B.
Did this ever get solved?
I have this issue after a recent server update; heaps of .par & .psm files not working
This is the 2D Free forum.  Given you have 3D files that are not working I would suggest contacting your VAR or GTAC for support since you are obviously not using the Free 2D product.
http://Grundey.blogspot.com
