File size difference with multiple save commands
Noticed an interesting thing when archiving some drawings this afternoon.
The file size changes with multiple Save commands.
I often submit ECN's with multiple draft tabs in one draft file, then when ECN is finalized, I split the multiple tab draft into individual draft files. Today I noticed that when I do this and have the single tab draft file and save it, the file size did not decrease much at all. Then when I saved it again, with no other actions to the draft file, the size decreased drastically. As an experiment, I displayed the background sheet tabs then hide them,  I don't delete the background sheets when archiving, and the file then increased in size on next save. The next save with no other action then decreased file size again.
Is this a 'Purge' command per say, or something else going on?
I attached a file I made in Word with screen captures of 5 saves in same file, other than 1st one which had all active tabs in it.
File size varied from 1.592 gig with 9 tabs down to 0.107 gig with 1 tab.
Gary Dinges | Mechanical Design Engineer II | Probes & New Product Development Emerson Commercial & Residential Solutions | Therm-O-Disc, Inc.| 1320 South Main Street | Mansfield | OH | 44907 | USA T +1 419 525 8554 gary.dinges@emerson.com
