Filename into document number field
is it possible to have the filename added to the doccument number field by default ?
Re: Filename into document number field
Hi there,
No, at least, not in the "File Properties" dialogue box,....but you can in the draft background sheet, by using the "%{File Name}" property text call out.
Testing: Solid Edge 2019
I have had a macro created for this ... thank you for the quick response
A macro was what came to my mind first, but thought it would be an overkill if a manual method or setting existed.
Could you tell if the macro you used is run for each file or its a batch process running on several files or a plugin ? Thanks.
~Tushar
not really sure ... I didn't make it ... had a programer at the company I work for look into it ... but it works for all types of files (par asm dft) and I just made a button on the ribbon bar that accesses the macro that I click after I name a files
Thanks for the update.
Was just trying to pick an idea for a new macro and this seems to be a good candidate.
~Tushar Suradkar
fb.pngSolid Edge Users Facebook Group
