Files Not Opening in Assembly
Does anyone else see this behaviour in assembly:
Right click on an assembly in the pathfinder and press open; wait for file to open and nothing happens. Do it again and the file opens?
G
Re: Files Not Opening in Assembly
Builder
Builder
I have not experienced this behavior.....but have experience similar behaviors. Usually a restart of SE helps me!
Which version of Solid Edge and the service pack ?
ST8 latest service pack. I have seen this behaviour in previous versions. Thanks G
I am also on ST 8 with MP 6, no doubt I could not re-create the problem.
~Tushar
Hi Graham,
Also cannot recreate this issue.....either with local files, or across a LAN.
Solid Edge ST10 [MP8] Classic [x2 seats]
