Find and replace in draft
We have several drafts associate to a plant, That plant is being duplicate like 4 times.... we need to replace string of text by someting else in each copy we create.
In an ideal world we would have use a custom peopertie to populate some fields, but unfortunatly those draft has simple text box or leader scartter here and there
Anyone aware of a find and replace macro available? to help us replace those text strings.
Re: Find and replace in draft
This is an old one that works on the active working sheet only.
LMGi
www.TLMGi.com
Thank you Jason
Hello @JasonTitcomb,
could you please provide the source code from SE_SearchReplace.exe?
Thank you for your help!
Fork it and make it better.
https://github.com/LMGiJason/SearchReplaceDraftForSolidEdge
LMGi
www.TLMGi.com
Thank you!
Working on it Smiley Happy
